06 Sportsman 800 voltage reads (incorectly) 18.5V
06 Sportsman 800. Last owner replaced the stator and regulator. He ran it with the flashing needle and flashing battery symbol for a year and no other issues. When I put in diagnostic mode, the voltage reads a steady 18.5V. With the engine off, idling, or revved.
Putting a meter on the battery reads 12.4 with the engine off, 12.8 at idle, and 14.6 revved over 3K.
I'm guessing that that the issue is in the speedo, but cant find any info other than "replace it". Has anyone ever seen this and/or repaired it?
Thanks
c473
Thanks
c473
Only thing I can think of is pulling the speedo harness connector for a few minutes and see if it resets and starts showing correctly. Voltage readings appear to show kinda ok with the meter. Battery voltage at rest should show a little more at 100 percent charge.As is about 3/4 charged. See if this site helps any. https://www.batterystuff.com/blog/ho...ry-is-bad.html
Battery was low, found the hand warmers wired direct to bat and inadvertently left on. Pulled speedo cable for 5 minutes. Checked voltage at the connector, none were more than bat voltage. Still read 18.5V, I'm guessing that is the max it is programmed to read.
So it looks like I'm taking this one apart.
Several posts on this that may help.http://forums.atvconnection.com/pola...ml#post3232409 KA7OEI's blog: Repair of the speedometer on a Polaris Sportsman 500 4-wheeler Plus you might check some of the spedo repair places such as this one. Down at the bottom of the page it gets to cycles/atvs.Speedometer Repair
Bdowney73
03-23-2017 06:56 AM
