Need a spreader to tow...
Old 12-11-2017, 06:20 PM
army_eod's Avatar
Default Need a spreader to tow...
Have a new Yamaha Kodiak 450.
Looking for some kind of spreader to tow with it so I can spread seed, fertilizer and and killer.
Any suggestions???
Thanks in advance.
Old 12-12-2017, 08:46 AM
hydrex's Avatar
Check out Northern Tools and DR company. You can also adapt ones with a 3 point hitch to regular hitch.
Old 12-12-2017, 10:26 AM
Devious6's Avatar
I purchased a motorized one that just attached to the back of the quad for spreading salt in the winter. It was OK, but I found that I got so much splash-back even with the directional disbursement that I was getting corrosion on the rear axles and pumpkin. It's sitting on a shelf in the garage now.
Old 12-12-2017, 10:32 AM
Kymco 450i's Avatar
Any suggestions???
Thanks in advance.
I bought a broadcast spreader from the local home depot and it worked fine for about two years, then it became so corroded from the chemicals it would no longer work. I rinsed it out after every use as described but it still corroded and that appears to be the same story others have given. I then decided to go liquid, bought a tank and 12v pump unit and mounted on the rear and that was about 7-8 yrs ago. Works great, easier to use and no corrosion. I have switched to liquid fertilizer and weed killer with better results. Seed still has to be dropped by hand but have a push broadcast spreader but for seed only so no corrosion.
Old 12-12-2017, 04:57 PM
YamahaMoto's Avatar
Country Rider
Does your quad already have a "Hitch" to attach something? check you local dealer and tools depot
army_eod
Utility ATVs
12-12-2017 10:49 AM
Quick Reply: Need a spreader to tow...
