were can i get an electric start for my mojave
Goki makes starter kits for a lot of old ATC's and quads, A couple of years back, I think Dirt Wheels did an install on a Mojave. The only drawback is mounting the battery, they had to put it in the nose area,under the plastic, and since there is no charging coil on the Mojave stator, you will have to recharge the battery after every ride (depending on how many times you use the starter) or have the stator rewound to put charging juice out, and wire up a regulator. Other than that, it isn't a lot of work to install and wire up, the kit will probably run about 250 bucks or so.
