Sport Quads Discussions on sport quads.
Paint?
Old Nov 10, 2005 | 05:10 PM
1bad450r's Avatar
Default Paint?
I want to paint the plastics and tank on my 250r. Anyone have any suggestions on what type of paint I should use here?
Old Nov 10, 2005 | 08:19 PM
spyder6's Avatar
Default Paint?
Krylon Fusion
Old Nov 10, 2005 | 08:43 PM
warriorguy22's Avatar
Default Paint?
Originally posted by: spyder6
Krylon Fusion
ditto
Old Nov 10, 2005 | 09:17 PM
spyder6's Avatar
Default Paint?
to get a great finish, try roughing the plastic up a bit with a 1000+ grit wet sand paper, layer it on with around 2 light coats of krylon primer, then 3 light coats of krylon fusion, and then seal it with a nice silicone based sealent (duh) and you should be set, remember before you put the primer on, to clean the plastics up with rubbing alcohol
Old Nov 10, 2005 | 11:40 PM
crazypainter's Avatar
Default Paint?
Fusion will not hold up. It will scratch off very easy. Stock ATV plastic is not designed to be painted. It requires a lot of work to make paint stick to it.
Old Nov 10, 2005 | 11:47 PM
Default Paint?
We painted a Fourtrax w/ fusion and it has lasted for over a year w/o any scratches or wear
Old Nov 11, 2005 | 12:12 AM
XtremeSkier's Avatar
Default Paint?
so in your case then..
what did it take for you to get ur paint to stick? you must have some secrets up ur sleeve
Old Nov 11, 2005 | 01:44 AM
1bad450r's Avatar
Default Paint?
Thanks for all the tips guys!! Crazypainter, how do you prep? I heard that if you paint the tank that the paint can bubble, is that true?
Old Nov 11, 2005 | 02:37 PM
Default Paint?
Your lucky you haven't scratched it cause thats where it will start to come off. Don't use a pressure washer on it either. Once it comes loose the pressure washer will rip it off.
Old Nov 11, 2005 | 09:26 PM
spyder6's Avatar
Default Paint?
odd, being as Krylon Fusion is especially made for plastic
care to comment on your painting styles?
