blaster mods
what are some good mods for my friends 04 blaster. and what is some good comp. for it. it already has bills full exaust system and stage 3 jets and bore .025 over
blaster mods
Do you mean only engine mods? I would start looking for some suspention upgrades (a-arms, swing arms, axles). What kind of tires does he have on it now?
The only thing really you could do with the engine is to get it ported and polished. |
Me and a buddy put a big bore kit on a Blaster then port and polished the head and an aftermarket reed... We really had no idea what we we're doing but when we were done, that thing would SCREAM!!! lol..
We had paddle tires on it and it would climb anything.... fun little quad! |
My friend had one bored up to 210ish and had extensive porting done and it was a monster.
Reeds make a huge difference, also you should look into hotcams, porting is also another very nice thing you can do.
my blaster....01....vito +3mm stroker,vito bigbore240,decked and milled head,,right at 270cc's,full fat bastard header and silencer,dyna jet kit,+3 on the swing arm,+6 (3 on each side)on the a-arms,banshee spindles and hydralic brakes all round,race cut fenders,oil block off...have to run 110 race fuel and it loves to drink it!!!!
i had a 240 vito and port and polish on my old blaster, and i loved it, aside from the fact that i had to rebuild it often, i like the power gain of the big bore kit...
as long as u check compression often.a new set of rings is all u need with a big bore..and the top end gaskets of coarse
That is one big disadvantage to big HP, is reliability. Maintnance is a constant thing as long as you have the time and $$$. I replaced the rings after 3 shows and pistons after 6 so you don't end up with a broken engine case. I really liked our B and it produced a ton of power, one thing that we did is bought a Airsal cylinder and had it coated which made it bullet proof if a piston did go.
