03 400ex wheels and spacers
Hello everyone, I'm about to order alba +2 a arms for my 400ex and the wheels on the front off set is 4+1 .. I can't afford a rear axle at the moment, but I can spacers.. so what size spacers do I need to compensate for the a arms and wheels.. I was thinking 1 and a half or 2 inch spacers.. any advice is appreciated.
Either will be fine. It doesn't have to be squared up front and back. If you are looking to get that thing in the air a lot I might go smaller spacers just because they can put a lot of extra stresses on the axle.
Originally Posted by Scooter86
(Post 3350985)
thanks a lot brother. If this was ur atv , what would u do? And if it isn't square won't that mess up handling? Thanks a lot for all the help. |
How aggressive do you ride? If it was my machine I would save up for this vs spacers
https://www.rockymountainatvmc.com/p...th-Racing-Axle |
(Post 3351017)
I would probanly just get the axle then. Aggressive riding with spacers is a recipe for a bent axle. And that one I linked isn't to expensive vs spacers either.
(Post 3351040)
If it is just the uni air filter it is unlikely you will need to rejet. Adding an intake kit, exhaust, or opening up the air box/lid and you will need to add some fuel.
(Post 3351068)
I am a big fan of uni/foam filters for anything off-road that sees mud or dust. Most stock Japanese filters are pretty good already and you won't see much benefit with just the filter in most cases. I usually have a few filters around so at any given time I have a clean one to throw on and can worry about cleaning the dirty one later. Clean well oiled filters are the way to keeping that engine happy. If the machine is already well tuned and jetted switching from stock to no toil to uni has never really changed much power wise for me. These things run best if they are a little lean, but that doesn't give you the longevity most people want. Running a little rich won't give you more power but does give piece of mind. If you are riding hard you are less likely to seize or cause damage. If you have doubts, go up one size on the pilot and main, see how you like it that way. Now if you are running stock and go to aftermarket exhaust you should have to rejet. Or adding airflow via altering the air box in some way.
