Jetting on an 88 Quadracer 250
Old May 26, 2003 | 09:46 PM
ClimbinQuadRacer's Avatar
Default Jetting on an 88 Quadracer 250
Ok guys, i am running a 90 over piston with an FMF Fatty Pipe with a Power Core Silencer and a clamp on K&N. What size main jet would be to run in it. Any help or info is apreciated thanks, KEV
Old Jun 5, 2003 | 01:24 PM
machman's Avatar
230 and read your plugs!
Old Jun 5, 2003 | 02:06 PM
Slacker1bob's Avatar
Where are you riding, Elevation? You may need to run about a 240 jet, but this isn't somthing we can tell you. You have to just check your plug. Jetting is not something you can just ask about. You have to run your quad and do the checks. We don't know your conditions and all the specs on your quad. Do you have aftermarket reeds? Any air box mods? Too many variable for us to guess about.
Old Jun 5, 2003 | 04:18 PM
I am at about 1000 ft. above sea level, i am not running an airbox at all im running a K&N Clamp on. I am running a 90 over piston(high compression on 116 octance gas) i was just curious what everyone else was running. I bought this quad off of my friend and have never messed with the carb so i was curious of what you guys were running.
Old Jun 5, 2003 | 06:39 PM
Jets are one of those things where it is a taylored fit. I ve seen nearly identical quads running different jets. The best thing to do is to really experiment and see what runs the best, while maintaining correct plug color.
ReconBayou
Oct 31, 2022 05:37 PM
XxS0ccerstarxX
Sep 24, 2015 02:02 PM
XxS0ccerstarxX
Sep 22, 2015 02:40 PM
Nosniborpapa
Sep 12, 2015 05:54 PM
XxS0ccerstarxX
Sep 8, 2015 12:02 AM
