is the coolant i put in ok?
Old Jun 22, 2003 | 02:35 AM
jt's Avatar
jt
Default is the coolant i put in ok?
everybody i've talked to said i could just put plain green automotive coolant in my z400..well i did it ...i didn't add water to it...is it ok? i used prestone
Old Jun 22, 2003 | 11:38 AM
stormnorm's Avatar
No...not OK!! You're supposed to mix 50 50 with water...green automotive is OK, but make sure you're at approx 50 50 with water. Your system will have a lower tolerance to temp. if you're only coolant!
1ArmBandit
55
Oct 14, 2015 09:03 PM
essonlaker
Sep 10, 2015 01:12 PM
Randy Lee Frye Sr.
Sep 9, 2015 02:30 PM
Kenidah
Sep 7, 2015 07:50 PM
