gas/oil mixture
For all of you who have a quadracer, what octane gas do you use? what oil do you use? and what ratio?
gas/oil mixture
In my 86 LT250 with a shaved head I ran87 octane on 20:1 mixture with Quicksilver brand oil from Wall Mart. My 91 LT250 I will probably run the same but cant say for sure because I’ve not got to really ride it yet due to the rear end tearing up in my truck.
gas/oil mixture
Hey I've done quite a bit of trying to figure this out,--Anyway heres what I run, it might not make your quad the fastest thing, but I believe it is safe, and moderate. I run 4.25 gallons of gas with 89 octane, with one bottle of Golden Spectro, (which is to be mixed with 5 gallons of gas for a 50:1 ratio). Well, hope this helps, its just what I like.
gas/oil mixture
i know there are more people on here who have a q'racer. i just want to know what you use.
gas/oil mixture
You might try a search. There have been a few threads just recently very similar to this one.
gas/oil mixture
I've always used maxima castrol927 w/112 octane @ 50:1. It's been good to me.
gas/oil mixture
50:1 seems a little low for the 927....
gas/oil mixture
Actually the 927 recommends between 20:1 to 60:1, I tried a 32:1, but I was fowling plugs too often, after several different mixtures I found that the 50:1 was correct for my zilla
