another starting question
Old Jul 9, 2003 | 01:08 AM
MalHombre's Avatar
Default another starting question
good call, craZ! i didn't think about that. i got double-row tapers in mine so it hasn't been a problem. plus i think it gave me a 8hp boost when i installed them. just be careful to torque them to spec.
Old Jul 9, 2003 | 01:16 AM
PUSHINTHELIMIT's Avatar
Try stuffing your **** in the spark plug hole!!! This should allow it to build more compression. Then have a friend pull 'er over!! It should start right up!!! If this don't work pack your ears with sugar, this will actually help a lot! And also don't forget to put your tounge inside the spark plug cap while your johnson is in the motor so you have sufficient spark... and by the way.... You didn't forget to put the legos in the crank case did you? If you didn't it's not helping, grab a handful of the SMALL BLUE ones and put them in the oil fill hole.... ONLY THE BLUE ONES!!! These ones have a special chemical againt that bond to the cylinder that help motors start VERY WELL! I bet you put in the yellow ones huh? don't forget to put a sufficient amount of large rocks in the gas tank too, this helps in good filtration and keeps the gas fresh for longer..... may be this is your problem?
Old Jul 9, 2003 | 01:17 AM
craZ400's Avatar
Careful MalHombre, sometimes them high perf. barings will come apart so hard they'll get stuck in yer pipe, then you have to drill a hole in the side of the midpipe to let the exhaust out.
And Jose are you sure your plug is firing? To check it, pull the plug out, reconnect the plug wire, hold the plug in your hand and try starting your bike, you should feel the plug start getting warm.
Old Jul 9, 2003 | 01:28 AM
Semms40oz's Avatar
Take the advice of craZ, but remember, if you feel a shock while trying that, its normal... keep doing it until the plug feels very warm, it worx, i kid you not
Old Jul 9, 2003 | 01:40 AM
  #15
MalHombre's Avatar
hey craZ, i ride mostly in my front yard with an occasional trip to 7-11 for a 40. do you think i should be worried about throwin' a rod?
Old Jul 9, 2003 | 01:46 AM
  #16
craZ400's Avatar
Only if you get to drunk and he (Rod) pisses you off, then you might end up throwing him. But if you do throw him, aim away from the bike, and for God's sake, don't spill your beer. It's alcohol abuse you know. I've seen men shot for lesser things.
Old Jul 9, 2003 | 01:56 AM
  #17
fender's Avatar
damn what a freaking dumbass GOD why do u even have a atv i agree with pushinthelimit "muddy newf" "lt 250r" sorry about my language
Old Jul 9, 2003 | 01:58 AM
  #18
fender's Avatar
no dont even go near your quad find something else to mess up i bet all of our quads run fine
Old Jul 9, 2003 | 02:44 AM
  #19
craZ400's Avatar
Fender, who was that last post to, or which post was it referencing, cuz from here it looks like your yelling at yourself. Did I miss a post that dissappeared or something? I'm so confused[img]i/expressions/face-icon-small-confused.gif[/img]
Old Jul 9, 2003 | 04:47 AM
  #20
MalHombre's Avatar
aim away from the bike.....Doh!
why didn't i think of that!
so you're saying with my liquid-cooled limited-slip beer koozie i should be alright?
