z400 jetting
Old Aug 4, 2003 | 06:23 PM
rec6937's Avatar
Default z400 jetting
i wanted to see if anyone can help me out with what main jet to use. i have heard 3 different opinion a 150, 155, or 160. my set up is pro circuit head pipe and silencer, aftermarket air filter, end of snorkal removed. i am leaving the lid on the airbox because of the conditions i ride in, but have considered drill a hole like i have seen others do.
Old Aug 4, 2003 | 07:34 PM
batgeek's Avatar
altitude?
i'm pretty close to sea level running a full CT system, K&N, snorkel removed, 3 2" holes cut in top of lid and run a 160 main.
Old Aug 4, 2003 | 09:46 PM
archerr2002's Avatar
I am at 1200' and running an HMF slip on with snorkle baffle removed and a 2x2 hole in the airbox lid. I am using a 165 main..
Old Aug 4, 2003 | 10:03 PM
deautaronomy's Avatar
Hey what filter you got!! The brown truck is bringing me a noss billet adpt and a uni for 60 bucks from e bay. Ive been running my stock one with the lid off.Your main jet is close to mine any probs or air screw adjusts.
Old Aug 5, 2003 | 01:38 AM
rivermobster's Avatar
Call PC and ask them what *they* recomend for there pipe!!! I run with a K&N and adaptor w/outer wears...and the air box lid off...160 main jet...stock needle lifted 2mm...and the air flow screw out one turn...with the stock pipe. Killer mid range punch!!
Old Aug 5, 2003 | 09:29 PM
I have the Noss adapter with the Uni filter and it is a sweet setup..I am running the stock needle and stock setting on the air screw setting. The machine runs like a raped ape!
Old Aug 7, 2003 | 02:27 AM
rec6937's Avatar
i got the job done today i used fmf/dynojet kit 155 jet, needle set on third knotch, and air/fuel mixture 3.5 turns out. procircuit said use it that way or leave stock setting and 160 jet.
Old Aug 11, 2003 | 12:08 AM
durabluz400's Avatar
rec6397,
Is that the third notch from the top? That is what I put mine on yesterday. I just got the FMF power bomb header and the power core 4 pipe, K& N filter. That is the notch the guy from Alba suggested I start it on! I also have a 155 main.
ReconBayou
Oct 31, 2022 05:37 PM
XxS0ccerstarxX
Sep 24, 2015 02:02 PM
XxS0ccerstarxX
Sep 22, 2015 02:40 PM
XxS0ccerstarxX
Sep 22, 2015 08:07 AM
Nosniborpapa
Sep 12, 2015 05:54 PM
