How to wir tether on z 400, PLEASE HELP
Old Aug 6, 2003 | 06:54 PM
stockbomb's Avatar
Default How to wir tether on z 400, PLEASE HELP
I am trying to hook up a tether on a Z 400 that is racing tommorow and I need help fast!!!
Old Aug 6, 2003 | 09:00 PM
Sparx277's Avatar
hey stockbomb, i have a tether on my fzr600 and looks like there is just a white(common),and a black(hot) wire. so what you would want to do if your system is similar think of it like this. bare with me i could draw this out easier than typing but here goes.
this tether is basically like a switch, when pulled it kills the bike so all that you have to do is make your wire connections at a point before your switch on your left handlebar(off,run) so determine the hot going to the (off,run) switch and the common and make your splices. you don't really have to solder them just use some scotch33 and you should be fine. Hope this helps you out. good luck
Old Aug 7, 2003 | 04:46 PM
quadmanz400's Avatar
just hook one end to the hot wire on your coil and the other to a ground I grounded mine right beside the coil. all the tether does is ground the coil and shut down the bike
Ragtop
Jun 27, 2015 03:04 AM
coolintheice
Feb 8, 2004 11:35 AM
anth
Jan 27, 2004 06:04 PM
MikeyBoyesq
Dec 22, 2003 08:30 PM
lt250rider
Sep 6, 2003 09:34 PM
