83 Suzuki LT125 Fuel Pump?
I have a 83 LT125 that I just got. It may a part missing. I got it started with starter fluid but it would not pull up any fuel from the low mounted tank. All the hoses are OFF the carb. If I hold the gas tank UP above the carb, it will start and run crazy - but at least it starts. Where, EXACTLY, do the hoses hook to so I can hook them up. Someone mentioned there might be a vacuum pump that hooks to the intake port between the carb and head on the intake rubber. There is also what appears to be a bolt vent? hose hookup that leans to the front. Where does that go? The fuel line is the only one I know is right, the one on the middle that pushes on from the rear. IS THERE supposed to be a little vacuum FUEL PUMP on this thing somewhere? There is a little round plastic **** on the top, front of center on the tank that mounts under the seat with no hose hooked to it.. What is that?
house1
Aug 9, 2015 10:49 PM
