water to my chest
Old Sep 28, 2003 | 09:15 PM
sparrow's Avatar
Default water to my chest
help !sank my z . and won't start .tried changing oil ,plug,filter,and drained carb! any suggestions ?
Old Sep 29, 2003 | 01:51 AM
teoamaru's Avatar
Unfortunately, I just did a similair thing with my car. (Sucked water up through the cold air intake) Well heres what you can try. Take your spark plug out and start cranking over the engine. Water might pump out the spark plug hole (hope for this). What happens is you get water in your cylinder and the piston can't compress. Causing things to break. Make sure you change your oil too. I'd recommend using some dry gas and 93 or 95 octane. When you get it to start listen for knocking and noises. (I've learned that water causes problems) Let me know what happens.
Old Sep 29, 2003 | 01:52 AM
teoamaru's Avatar
By the way starting fluid works wonders [img]i/expressions/face-icon-small-smile.gif[/img]
Old Sep 29, 2003 | 05:52 PM
sparrow's Avatar
thanx , i'll try that
Old Sep 29, 2003 | 08:01 PM
sparrow's Avatar
did't work should i drain the tank and try new fuel? it turns over fine but it just won't fire
Old Sep 29, 2003 | 09:39 PM
teoamaru's Avatar
Did any water come out the spark plug hole? And yes I'd drain the gas and run dry gas through it with 93 or 95 octane, if this doesn't work I'd probably take off the cylinder and check out your piston and head.
Old Sep 29, 2003 | 09:40 PM
teoamaru's Avatar
Also did you try the starting fluid?
Customer Service #1
May 15, 2020 08:46 AM
panicmanic
Sep 28, 2015 12:59 PM
MikeyBoyesq
Sep 22, 2015 10:02 AM
MikeyBoyesq
Sep 7, 2015 10:44 PM
