Rev limiters Z400
Old Sep 29, 2003 | 01:03 AM
Goliath442's Avatar
Default Rev limiters Z400
Has anyone changed there rev limiter on there Z yet? How does it work? How much did it cost? And can you get it in Canada somewhere?
Old Sep 29, 2003 | 11:03 AM
witti's Avatar
do a search on reverse, I did it by installing a jumper wire by the cdi, it works great.
The post was by CRAZ400 or something like that, a member named freakazoid replied with the instructions that I used.
Old Sep 29, 2003 | 12:27 PM
Zhvonte's Avatar
you can order a cdi box from dynatek. It's a four channel deal, with one being the stock setting. The rev limitor can be adjusted via computer as well as the power curve. Keep in mind if you are intending to run prolong period of 9000 rpm or more, I be concerned with valve floating. The cdi box was adjusted for how the engine was built, and we got it set at 11,600 rpm. With the upgraded srpings/valves, it doesnt float at all.
Old Sep 29, 2003 | 03:39 PM
witti's Avatar
sorry, I thought you wanted to override the reverse rev limiter.
DGNAZ
ATV Expeditions
Jun 22, 2017 04:20 PM
NewGuy2481
Oct 6, 2015 05:54 AM
XxS0ccerstarxX
Sep 22, 2015 08:07 AM
1ArmBandit
Sep 8, 2015 08:59 PM
Steeldon
Utility ATVs
Sep 5, 2015 09:38 PM
