Synthetic Oil?
Old Oct 21, 2003 | 03:30 AM
Blaster2fast's Avatar
Default Synthetic Oil?
I was planning on running synthetic oil after my warranty ran out... 5 more months, the guys at the dealer said dont do it ebcause of the cluth and the clutch is a wet cluth so it uses the oil and that if i use sythetic it might slip... what do youguysdo?
Old Oct 21, 2003 | 03:31 AM
O sorry this is for the KFX400 and the 660R, will be running both on the sythetic... we are runnign the honda foreman and the polaris 400 on them and they are having no problems... but they dont have clutchs... hmmm
Old Oct 21, 2003 | 09:52 AM
reconranger's Avatar
Red Rider
Honda, accept nothing less!
I have read that there are advantages and disadvantages to both petrolium and synthetic oils. So, I run Honda HP4M Synthetic/Petrolium Blend with Moly. THE BEST OF BOTH WORLDS!! But, can't be used in an autoclutch bike.
Old Oct 21, 2003 | 01:09 PM
ZigZilla's Avatar
Use amsoil....simply the best oil , grease, 2 stroke oil out there... [img]i/expressions/face-icon-small-wink.gif[/img] amsoil
Old Oct 21, 2003 | 07:56 PM
Eigeraholic's Avatar
Amsoil!! Had it it my 5sp Eiger for last 800 miles, no problems at all. The fan would run every once in a while during break in with dino oil in 40 deg weather. I left it sit for 45 min in 80 deg heat with Amsoil in it before the fan came on. I use Amsoil in everything.
03 Eiger 5sp 4x4 green
Old Oct 21, 2003 | 08:05 PM
ScoobyDFW's Avatar
Look for JASO MA rating on motorcycle specific synthetic oil to be sure it will work with the wet clutch. In general as of very recent, due to the latest automotive oil standards, automotive oil is not good for ATV/Motorcycle applications.
Old Oct 21, 2003 | 08:13 PM
JesterZ440's Avatar
amen, only the best...
Old Oct 21, 2003 | 10:14 PM
amsoil makes many differnt synthetic oils... is there any certain kind that i should be using? in my garage weve got NAPA sythetic 5w-30 (or 40 i dont remeber) maximum performance and castrol sytheitc blend.
Old Oct 21, 2003 | 10:33 PM
ScoobyDFW's Avatar
I wouldn't use the 2000 series amsoil, it is rated JASO MB which has very low friction that might affect your clutch.
Old Oct 21, 2003 | 11:34 PM
lt230racer's Avatar
im using this synthetic oil for atvs that has wet clutch additives. i got it at farm and fleet. it works good.
