No airbox?
Old Oct 24, 2003 | 03:02 AM
Blaster2fast's Avatar
Default No airbox?
pros and cons? how would a clamp on UNI with a outerwear and no airbox work out? what kind of condistions would make this a NO-NO?
Old Oct 24, 2003 | 01:22 PM
Default No airbox?
bump
Old Oct 24, 2003 | 03:57 PM
Corpsie's Avatar
Default No airbox?
You'd only want to do it in dry environment (no standing water, etc..)
I'd suggest using the airbox (with all the walls cut out) as a frame to hold outwears all around and off of the filter.
Old Oct 24, 2003 | 04:46 PM
FsT4WrD's Avatar
Default No airbox?
I would'nt do it unless you plan on only riding stadium supercross tracks
Old Oct 24, 2003 | 05:50 PM
Starky's Avatar
Default No airbox?
Just removing the lid should be all you need to do. Taking the whole box out isn't gooing to give you any more advantage and the disadvantages are great.
Old Oct 24, 2003 | 11:04 PM
MalHombre's Avatar
Default No airbox?
i'm planning on running a clamp-on. other than deep water, what's to worry?
planning on making a deflector to keep rear tire spray down to a minimum.
Old Oct 25, 2003 | 08:48 AM
strokertwo's Avatar
Default No airbox?
I run a K&N slip on (w/outerwear)no air box on my LT250R.I had to becuase I change my carb to a 39mm Kuhien and my air box would not fit the air intake side of the carb to big.If you stay out of standing water you will be OK. I have rode in alot of slop with no problems and with the bigger carb and much improve air flow my 250r screams. Just my 2 cents. LoL.
1986Vmax540
Jul 9, 2021 09:53 PM
Canamaniac!
Sep 15, 2015 06:19 PM
mbriggs
Sep 13, 2015 10:47 AM
Dammar
Aug 26, 2015 07:12 PM
ghost civic
Jul 20, 2015 12:36 PM
