susuki Z-400 swing arms
Old Nov 4, 2003 | 08:53 PM
Goliath442's Avatar
Default susuki Z-400 swing arms
Has anyone had trouble with there swing arms always coming loose so that the chain never stays tight and what did you do to correct this nightmare of a porblem?
Old Nov 5, 2003 | 02:31 AM
kruzoffman's Avatar
will i have a LT the swing arms are the same, what i did is get a cheater bar on the end of your ratchet or rinch( what ever you use to tighten you swing arm bolts)if you dont know what a cheater bar is its a long bar or somethins that will fit over your ratchet. it gives it more liverage then just tighten them as hard as you can. good luck.
Old Nov 5, 2003 | 02:47 AM
batgeek's Avatar
yep, tighten em HARD.
Loc-tite is yer friend also [img]i/expressions/face-icon-small-smile.gif[/img]
Old Nov 5, 2003 | 08:30 AM
truckpaul's Avatar
They're hardened bolts, crank the h*ll out of them, they'll stay tight!
fd24
Jan 16, 2019 08:59 AM
jdunne01
Oct 4, 2015 10:29 AM
Ahtatu
Sep 28, 2015 12:14 PM
Todd C Wadas
2) Chassis problems..
Sep 23, 2015 11:31 PM
Canamaniac!
Sep 4, 2015 06:44 PM
