Z400 Jetting/Needle
Old Nov 10, 2003 | 12:40 PM
Duneman09's Avatar
Default Z400 Jetting/Needle
A computerless friend of mine needs help. He is putting the Jet Kit in his 400 and is having a hard time trying to get two little phillips screws out to get at the needle to replace it with the one in the kit. Any suggestions other than a "real good" phillips screw driver or slightly taping the screw head ? Also is changing the needle "absolutely" necessary? Any and all proceedure steps for changing the needle will be appreciated. Thanks in advance...
Old Nov 10, 2003 | 06:46 PM
LTZ's Avatar
LTZ
You may need to slot the head with a Dremel or something else and use a flat head to get them out, some of them can be a bi!@#!!! Change them to a hex head or allen screw once you get them out, makes it alot easier next time!!
If he piped it and put a filter on he will have to change the needle or use washers on the stock one to get it right.
Hope this helps...........
Old Nov 11, 2003 | 01:27 AM
bailey01's Avatar
Tell him to get an impact driver ( 13 bucks from auto part store). As far as the needle I just moved the top washer to the bottom and it is fine with a 170 main jet.
NewGuy2481
Oct 6, 2015 05:54 AM
XxS0ccerstarxX
Sep 22, 2015 08:07 AM
1ArmBandit
Sep 8, 2015 08:59 PM
Jul 15, 2015 02:07 AM
yambam13
Jul 4, 2015 01:49 PM
