z400 rev box
Old Nov 12, 2003 | 02:34 PM
Christoblue's Avatar
Default z400 rev box
I'm planning on pipeing my dvx400 and was wondering if anybody has had to put a rev box after you piped your z400. If so where did you get it and for how much? I know on a 400ex you really need the rev box with a pipe.
Old Nov 16, 2003 | 10:47 PM
Blaster2fast's Avatar
WB has one it will raise up 1000rpm ibelive
Old Nov 18, 2003 | 09:45 PM
balzy's Avatar
yoshi also has 2 rev boxes coming out
Old Nov 24, 2003 | 04:05 AM
lets bump this and see if anyone else knows anything
Old Nov 24, 2003 | 02:20 PM
KGB's Avatar
KGB
Curtis Sparks told me the Dyna is the way to go. Programmable and $400.
I am debating it.
Old Nov 24, 2003 | 11:29 PM
Fastz440's Avatar
I recommend the dyna, I've had it on my z for a month and it's great. I got mine off of ebay
Old Nov 25, 2003 | 02:27 PM
lsittingbull's Avatar
Does the Dyna allow for clutchless shifting?. And fastz440 did the Dyna give you allround power or extend your Rpms.
Old Nov 25, 2003 | 10:58 PM
Fastz440's Avatar
I did 3 mods at once,Droped a tooth on front sprocket, removed air box, and installed ignition. I can only say for sure that it will rev alot higher with this ignition. I should have done the ignition only to get a comparison from the stock CDI. But with the 3 mods together BIG difference, alot more torque,revs through the gears faster and higher shift points. most of the gain was from the spocket
I definatly do not miss the factory rev limiter...
NewGuy2481
Oct 6, 2015 05:54 AM
XxS0ccerstarxX
Sep 22, 2015 08:07 AM
1ArmBandit
Sep 8, 2015 08:59 PM
Jul 15, 2015 02:07 AM
yambam13
Jul 4, 2015 01:49 PM
