lt250r mod question...
Old Nov 17, 2003 | 01:11 PM
robarrior's Avatar
Default lt250r mod question...
I own a 1990 lt250r and yesthurday it was my true first ride around dunes and trails...not very confortable, its like i was fighting with the machine!
So am asking, how can i make the machine more confortable and more enjoyable to drive? low cost solution please...
Old Nov 17, 2003 | 04:39 PM
VegasQuadracer's Avatar
You need to be more specific. I had an 89 and it felt great to me. In fact in it's day, it was considered to have better ergonomics than the TRX250R! How tall are you and what's your weight? Is the suspension stock? What didn't you like about it? It's still the lightest 250 production sport quad ever built to my knowlege!
Old Nov 17, 2003 | 04:56 PM
Bubba297's Avatar
The rear shock does have adjustability. The ones with some usage tend to have a crappy back shock that needs rebuilding. Doing a rebuild makes a huge difference if it needs it.Other than that we do need some more input.
Old Nov 17, 2003 | 07:30 PM
robarrior's Avatar
Ok, i'm 5'9", 185 pounds. My lt250r is stock except for the pipe. The big problem is the front suspension thats too stiff. I was thinking about doing a little swap on the front suspension, putting something from another atv with a longer travel and softer. Is it possible?
Old Nov 17, 2003 | 11:27 PM
NichelsonRacing87's Avatar
there isn't really any other quad that has more travel than the 250's, unless you try putting something from a Banshee or Raptor or any newer quad because the technology on these newer quads are so much greater than older ones like the LT's and TRX's. The TRX has a greater front travel than the LT but not much. Or you could search around for aftermarket shocks and a arms.
Old Nov 18, 2003 | 10:45 AM
ShadyRascal's Avatar
To remedy this you do need longer a arms and shocks. The HSD stuff is the best there is, but real spendy. You can get +2" a arms, but if you do you need to get ones with the shock mount moved outward as the LT has a bad suspension travel/shock travel ratio and longer arms make this worse. Let me know if you want to pursue this and I will give you all the gory details. [img]i/expressions/face-icon-small-cool.gif[/img]
Levi Enstad
Sep 26, 2015 08:00 AM
Halffast17
Sep 11, 2015 02:30 PM
QuadCity
Aug 13, 2015 12:58 PM
VRRRRT
Jun 27, 2015 09:38 AM
BiGMiKe
Sep 1, 1999 07:50 PM
