500cc Quad?
Old Nov 21, 2003 | 09:51 AM
Genesis's Avatar
Default 500cc Quad?
I am new to ATV's and traded an old snowmobile for an old suzuki Quad.
I am told it is a "QUADZILLA" 500cc.
The serial number is: JSAAM11A9H2100xxx
here is a picture of it:
http://www.buffalonet.com/imag0066.jpg
Can anyone tell me anything about this machine?
I was told it is a Suzuki Quad from the mid-eighties. It is Blue(Seat/Engine) and Yellow trim.
It is dirty and the plastic is cracked a bit but it supposedly runs but I'm not quite sure how to go about checking it over before attempting to start it. I know sleds fairly well but quads I have no clue. Does this thing need a key to be started? I wasnt given one by the guy I traded to. Is it gas/oil premix? There is a radiator on it but how do I fill it?
thanks for any info you guys can lend!
Dylan
Old Nov 21, 2003 | 10:28 AM
ShadyRascal's Avatar
Default 500cc Quad?
Yes, you have a Quadzilla. That is an '87. You do mix gas, at 32:1 or 40:1 whatever you prefer. Make sure there's oil in the tranny, or better yet change it first. The radiator's right under the blue front plastic. If it needs a key, the switch would be right behind the light on the handlebars, otherwise just use the handlebar kill switch as an on-off switch. Those are desirable 4-wheelers.
Old Nov 21, 2003 | 12:25 PM
Duneaddict's Avatar
Default 500cc Quad?
Wow, what a trade!
For starters, you'll probably need to pull the carb off and clean it up (I'm sure you've done that on a sled before)
if it's stock, it will be a flat slide mikuni... nothing hard at all.
Make sure the rest of the fuel system has been flushed also.
next you'll need to clean and/or replace the air filter element (If its sat for a long time, the foam has probably degenerated)
as suggested, change the gearbox oil, new plug (verify it has spark... )
mix a good quality oil at 32:1 with the highest octane fuel you can find... fire it up..
Welcome to one of the most powerful quads ever built!
Good luck!
Old Nov 21, 2003 | 12:36 PM
Genesis's Avatar
Default 500cc Quad?
Thanks for the help everyone. Now the tough question: I'm 6'6" and around 360lbs. Should I ride this machine?
I'm told that being a large person I would tend to tip this thing over a lot. any advice?
I will take all your input and have the quad professionally gone over and cleaned and tuned.
That being said, if I wanted to get rid of it after that would can I expect to get for such a machine?
-Dylan
P.S. the sled I traded for it was worth ROUND $600.00USD, Did I get a deal or did I get screwed?
Old Nov 21, 2003 | 01:52 PM
AgressiveRider's Avatar
Default 500cc Quad?
I'd say you got a pretty good deal since quadzillas are getting rarer and rarer. You should have any problem riding this thing since you are a bigger guy. If you got the money this thing could become a project![img]i/expressions/face-icon-small-smile.gif[/img]
Old Nov 21, 2003 | 06:31 PM
Blaster2fast's Avatar
Default 500cc Quad?
if in good condition a minimum of 3 grand i would say
Old Nov 21, 2003 | 08:01 PM
sam250's Avatar
Default 500cc Quad?
You've got the biggest, fastest production quad ever built. Good deal is an understatement. Even if you have to rebuild the engine it's still a good deal. Check out the LT forum at macdizzy.com. There is a thread over there called "LT500 motor Rx" that has tons of info about your engine.
Old Nov 21, 2003 | 10:10 PM
Hozed's Avatar
Default 500cc Quad?
how fast do the 500 goes stock...
Old Nov 22, 2003 | 02:28 AM
chuck1221's Avatar
Default 500cc Quad?
stock - i've heard 80 - 82
modded - very fast
chuck
Old Nov 22, 2003 | 05:05 AM
No2StrokeBs's Avatar
Default 500cc Quad?
Going by the A-arms, you have an 87. Do everything DUNEADICT recommended, and if you want to part it out, I got dibbs on the engine.
