Jetting HELP....LT 250R
Old Dec 8, 2003 | 02:10 PM
strokertwo's Avatar
Default Jetting HELP....LT 250R
I have a 87lt250r with a Keihin PJ 38mm I'm haveing a little troblem getting the jetting right, I'm useing a K&N filter Slip on it also has a FMF Fatty w/ Power core silencer. LS jett 48, Needle Clip 4 pos, Diamerter is a letter L, and HS jett is 170. Bike start up fine Idle's good when I let it warm up and go to take off at about 1/4 th. it seem like it's loaded up from idleing but clears up after I get threw 2nd and 3rd gear and after riding for a while there is no problem when shifting threw all the gears. Did a plug check and it seems to be running rich in the mid range. Can i go all the way to the top notch on the clip(needle) Or should I go next size diameter needle, it's the gold color needle with the 3 letter lable system which would put me into M. Any help would be great........
Old Dec 8, 2003 | 04:11 PM
Flynbryan's Avatar
No matter how good you have a two-stroke jetted its going to load up when just idleing. Its just the nature of the motor. If it doesn't run poorly, and carburates smoothly I wouldn't mess with it.
ReconBayou
Oct 31, 2022 05:37 PM
XxS0ccerstarxX
Sep 24, 2015 02:02 PM
XxS0ccerstarxX
Sep 22, 2015 02:40 PM
Alex Rodak
Sep 13, 2015 12:30 AM
Alex Rodak
Sep 12, 2015 09:39 AM
