What are some sighs that the rear axle/chain adj is not aligned?
Old Dec 29, 2003 | 02:01 PM
JOEYG's Avatar
Default What are some sighs that the rear axle/chain adj is not aligned?
Hi, I have a 03 Z 400 and I am trying to adjust the chain and it is driveing me crazy, what are some sighs that the the rear is not aligned properly? are the hash markets pretty close? where can I messure from? I think the front axle to teh rear axle has a few to many variables?
Also if I turn in a complete circle to the left the quad wants to tip more than if I turn in a circle to teh right. Thanks a a lot
Old Dec 29, 2003 | 02:58 PM
RaptorRidr660R's Avatar
do a wheelie and see if you go straight or curve off to one side, thats the easy way!!!!
Old Feb 15, 2004 | 07:51 AM
JOEYG's Avatar
Anyone else? thanks
Old Feb 15, 2004 | 10:27 AM
MBrooks420's Avatar
No need for 3 seperate threads for the same problem. Jack up the rear end, and put it in gear and spin the tires. look to see if the chain is tracking straight or being kicked off to one side.
Old Feb 15, 2004 | 10:46 AM
terd's Avatar
the best way is to do what i wwrote the last time.trust me on this,it is the most accurate.the wheelie method doesn't work because even if one of the wheels was pushed in all the way,it would still go straight,only that the quad would look like it's leaning to one side
Old Feb 15, 2004 | 04:01 PM
hondabuster's Avatar
The wheelie method wont work, that will just show how equal the rear tire pressure is.
Jack up the rear end, and spin the tires, either by hand or with the motor and look at the chain and sproket, if its crooked youll see it.
Or just use the hash marks, they should be the most accurate way.
Canamaniac!
Sep 15, 2015 06:19 PM
bmark0610
ATC 3-Wheelers
Sep 7, 2015 07:57 PM
bmark0610
ATC 3-Wheelers
Sep 7, 2015 07:48 PM
