Is It Safe ???????????????
Old Jan 6, 2004 | 07:53 AM
vinsonsuzukiismyquad's Avatar
Default Is It Safe ???????????????
well thanx guys i shall do that well i have to go to tschool now so ill let you know whats happenin' ok
Old Jan 6, 2004 | 01:31 PM
Specialyst's Avatar
its says on master cylinder do not mix dot 3 and dot 4
Old Jan 6, 2004 | 02:00 PM
ad me if you guys have msn ok
john_lennon46@hotmail.com
add me ok please and ill talk to you and tell you what my guy said to me and this is what the person who fixes my quad said to me ok and he is a mechanic so ha be that way and pluse it is too late i alreadyput some in so ha
but thanx any ways
Old Jan 6, 2004 | 02:31 PM
hondabuster's Avatar
After checking into it more...If your system is a dot3 system, then its ok to add dot 4. However, if your system is a dot4 system(check your owners manual) then its not ok to add dot 3.
Dot4 fluid has a higher boiling point than dot 3, so dot 4 specs, excede dot 3. A dot 4 system may be designed to run at higher temperatures than a dot 3 system, in which case...you wouldnt want dot 3 in there. So if you ride hard, and use the brakes hard, you should have dot 4 in there.
Old Jan 7, 2004 | 01:07 AM
  #15
Dragfameson's Avatar
It's fine... he's mixing it, not just using straight Dot 3. Like you said, if it calls for Dot 4 then yes, you should have Dot 4 in there, but it's okay to mix Dot 3 and 4 together, he wont have any problems with that....
Old Jan 7, 2004 | 03:13 PM
  #16
well it says to use dot 4 but guys get this i don't have any and i don't want to go to the dealer and get some but those of you who live in canada does canadian tire sell any dot 4
if they do please tell me ok
Old Jan 7, 2004 | 03:15 PM
  #17
Specialyst's Avatar
the average auto parts store has it.
Old Jan 7, 2004 | 04:12 PM
  #18
Its cold up there anyways, I wouldnt worry about it.
Old Jan 7, 2004 | 04:14 PM
  #19
hey speicalyst where go you live ? anywyas do you live in canada so where would you ssay i would buy this short of stuff? let me know ok
Old Jan 7, 2004 | 04:16 PM
  #20
Have you ever been to canada? Well i have to tell you that it is not cold up here infact i have lived here for 18 years all i have to say is that it is not cold up here ok
