shift pedal adjustment
Old Jan 9, 2004 | 05:43 PM
GTFZ250's Avatar
Default shift pedal adjustment
On the Z250 there are splines or little teeth where the shfter is attached is ther a way to adjust it up so that I dont have to like yank up to shift or would it be a waste of time and energy?
Old Jan 9, 2004 | 10:25 PM
SpankyLowe's Avatar
Yes just pull it off and move it up a notch or two,,,I think that most of us guys that have little Z's have had to do that as well,,,,,,very simple......
Old Jan 10, 2004 | 12:44 AM
Perwho's Avatar
You can fine tune it by loosening both the bolt's behind (or in front of) the little rubber boots, and then turn the rod in the direction you want. Then retighten the bolts and done........[img]i/expressions/face-icon-small-cool.gif[/img]
Old Jan 10, 2004 | 12:30 PM
CHEWBACCA's Avatar
wouldnt it be better if you moved it down so u didnt have to bring your foot up so high?
Old Jan 10, 2004 | 03:29 PM
CTATV's Avatar
maybe there feet dont fit well under the shifter and they are moving it up so they dont have to squeeze it under the lever. Ive had mine down and almost broke my foot off cause my toes got snagged by a rock
Hw00d
Sep 10, 2015 08:53 AM
bmark0610
ATC 3-Wheelers
Sep 7, 2015 07:54 PM
Elkaholic
Sep 6, 2015 02:44 PM
Steeldon
Utility ATVs
Sep 5, 2015 09:38 PM
vtech
Help With Forum Software!
Sep 2, 2015 05:59 PM
