Zilla carb on my lt will it work
Old Jan 16, 2004 | 02:39 PM
f250r's Avatar
Default Zilla carb on my lt will it work
i picked up a 38mm zilla flat slide on ebay, will it fit in the intake boot on my LT250R
Old Jan 16, 2004 | 03:08 PM
LT250RSuperstar's Avatar
No, I don't think it will fit so.....more than likely your gonna hafta make a flange that will or buy one if ya can....
later
Superstar
Old Jan 16, 2004 | 05:26 PM
f250r's Avatar
any body done this before, i just checked out the carb boot it is almost exsactly the same OD. and the carb so should i just make a coupling out of radiator hose or something ? and how come there is no idle screw on the 38mm mikuni carbs, do u just adjust it from the throttle cable?
Old Jan 16, 2004 | 07:18 PM
Slacker1bob's Avatar
I tried a quadzilla carb once. On my 86 I was able to turn the boot around and it worked, but since you have a 89, you boot is fixed. You can try letting your boot sit in the sun to warm up and get flexible. It may then fit. Also, if the carb that you got has no idle adjustment, then it is broken, because they have a idle screw.
Old Jan 16, 2004 | 08:45 PM
Supernut's Avatar
I fit one. it was a bitch but you can stretch it on there. just force it
Old Jan 16, 2004 | 09:33 PM
f250r's Avatar
i dont knw maybe its not a zilla carb, but it is almost the same as my 34mm stock carb only its 38mm. but there really is no idle screw not even a spot there. whats up with that ill post a pic so u can see. even on the inside of the carb theres no hole for the idle screw it is really weird.[img]i/expressions/face-icon-small-confused.gif[/img]
Old Jan 16, 2004 | 09:37 PM
bigugly's Avatar
Ditch the airbox and get a clamp on k&n filter that fits your bigger carb.
Old Jan 16, 2004 | 09:51 PM
f250r's Avatar
i have a clamp on k&N the carb wont fit in the intake boot
Old Jan 16, 2004 | 09:54 PM
Zilladaddy500's Avatar
yes it will work,you have to set it in hot water to soften up the rubber,but it will work.
Old Jan 16, 2004 | 10:01 PM
f250r's Avatar
cool thnks for the tip [img]i/expressions/face-icon-small-happy.gif[/img]
