Need for jetting????
Old Jan 22, 2004 | 09:26 PM
mutso's Avatar
Default Need for jetting????
Just bought an '03 Z400. It has a full Yosh pipe but stock air filter. When I put on a K&N, will I need to jet the carb, or will stock jet be okay? I am not a racer or crazy-man, just need power for the dunes.
If I should jet, does anyone have a link to a relatively inexpensive (Yeah right) K&N filter/jet kit?
Thanks in advance for your help.
Mutso
Old Jan 22, 2004 | 11:39 PM
Trx250Time's Avatar
you need to re adjust your carb to let the higher air flow in from the k&n and depending on how old your quad is you might need jetts with a piepe as soon as 15 hours are on i would re jett for the first time
Old Jan 22, 2004 | 11:40 PM
Trx250Time's Avatar
you need to re adjust your carb to let the higher air flow in from the k&n and ya u need jetts
Old Jan 22, 2004 | 11:41 PM
Trx250Time's Avatar
srry i didnt reead the 2003 part
Old Jan 23, 2004 | 12:29 PM
z400nate's Avatar
yes, you will have to rejet, rockymountainatv.com has a k&n jet kit for around 45 bucks plus s/h. if you dont rejet, you may find your quad not utilizing the power it could be had it be jetted properly.
Old Jan 23, 2004 | 04:28 PM
z250master's Avatar
You should rejet..with your new pipe more air is coming in, but the same amount of gas. Your z400 will do MUCH better with a jet kit, and its not that hard to do either.
Old Jan 23, 2004 | 04:37 PM
mutso's Avatar
Thanks for the help!!
Old Jan 23, 2004 | 05:11 PM
Slacker1bob's Avatar
I wouldnt bother with a jet kit, just go buy the next 3 sizes, but skip the very next two up from the stock that you got. $14 vs $45
ReconBayou
Oct 31, 2022 05:37 PM
XxS0ccerstarxX
Sep 24, 2015 02:02 PM
XxS0ccerstarxX
Sep 22, 2015 02:40 PM
Nosniborpapa
Sep 12, 2015 05:54 PM
XxS0ccerstarxX
Sep 8, 2015 12:02 AM
