New guy needs help witha smoking LT 250R
Old Feb 8, 2004 | 01:54 PM
Diskomonky's Avatar
Default New guy needs help witha smoking LT 250R
Hello,
Jutst signed up, Just wanted to say; you all have been a great wealth of info. Hopefully you can help me. I picked up a 1987 LT250R that was in poor shape, Smoked like I have never seen a bike smoke, replaced bearings, bushings, breaks, etc. I had the top end re-sleeved and with a LA sleeve, and weisco piston of stock bore. head gasket repolaced and all assoc. gaskets, pulled clutch cover off and replaced crank seal on that side only, as my thought was that it was sucking oil from the wet side. after it was all put back together, I started it up and it smoked, I took it for a rip, after letting it break in, and appeared to be clearing up, with occasional blue if I was sitting for a minute, when wide open in 5th gear, I thought the throttle was stickiing open because It woulsd stay wide open, but I learned this could be because it is running lean, Help!!!!! After market pipe and fmf muffler.
Thanks
Old Feb 8, 2004 | 08:05 PM
LT250Rodney's Avatar
Get some jets and get to work. If its lean then keep going up a size or two at a time until the plug is a nice golden brown color.
Old Feb 8, 2004 | 11:13 PM
Diskomonky's Avatar
I pulled the main jet out, it has the #430 on it, The only nomber on the carb is T6 Y2 and below it is 43B, I know nothing about the Mikuni carb, does any on know what those numbers stand for, I am starting to think it is a bigger carb.
Old Feb 9, 2004 | 12:33 AM
ProComp's Avatar
Somethings not right with that carb. Mine is an 85, stock is 190 and mine had a 220 in it.
430 seems way off.
EIF
Apr 20, 2017 07:15 PM
Alex Rodak
Sep 13, 2015 12:30 AM
Alex Rodak
Sep 12, 2015 09:39 AM
Alex Rodak
Sep 11, 2015 11:42 PM
