bump steer
Old Feb 16, 2004 | 10:34 PM
kruzoffman's Avatar
Default bump steer
hey i was wanderan if someone makes a bump steer elimnator kit for the LT250r i thote i heard somthing about some company making a bump steer elimnator kit so if eney body know's were to find one i would appreciate it[img]i/expressions/face-icon-small-smile.gif[/img]
Old Feb 17, 2004 | 12:40 AM
JustinJones's Avatar
Default bump steer
there used to be a really weird "bump steer kit" back in the 80s people put on LT250Rs and Tecate 4s... They're no longer popular nowadays probably for good reason. from what I've read, they had a lot of added componentry.
Bumpsteer is caused when the tie rods and A-arms have different plans on what to do over a bump or any kind of compression event.
measure your top and bottom A-arm's length, measure your tie rod's length. Make/modify your tie rods/steering arm so your tie rods are about the same length and angle as the A-arms, set the toe-in to about 1/8" to start out, and change it as you see fit to aid handling/bump steer.
Old Feb 17, 2004 | 02:54 AM
LT250RSuperstar's Avatar
Default bump steer
Actually Mark from HSD RACING can help ya on this one cuz I think he does or can make a kit.
later
Superstar
Old Feb 17, 2004 | 07:59 PM
800screws's Avatar
Default bump steer
he does?? it's not on the website is it? i never heard of this before.
Old Feb 17, 2004 | 09:42 PM
kruzoffman's Avatar
Default bump steer
wow thats cool justinjones were did you learn that trick, so you modify you steering stem so your tie rods are the same length as you a arms.
Old Feb 17, 2004 | 11:30 PM
dissimilar's Avatar
Default bump steer
1) Use a steering stabilizer. That should be your cheapest and easiest solution. The stabilizer does not solve the problem since the front end geometry/relationship will still be wrong but some of the negative effects will be lessened.
2) Polaris had a good explanation of bump steer in the ATV mags when their Predator first came out (The Predator is said to have "zero bump steer"). They explained why some quads were better than others in this regard. Many modern OEM and aftermarket frames are VERY narrow in the front in order to keep the A-arms and tie-rods in line with each other.
3) Make sure you never mention that the LT500R has terrible bump steer compared to other quads. The last time I did that I got my head bit off by a group of posters with no idea what the term even meant. For some people, talking down on the big LT is like insulting their mother. I own one but I’m not blind to its shortfalls!
Old Feb 19, 2004 | 05:46 PM
kruzoffman's Avatar
Default bump steer
oh so do ya think the lt500 has more bump steer then the 250? i was thinking about one of those steering stabilizer's but waz not sure are they eney good
Sep 30, 2015 01:37 AM
35dodge
Sep 29, 2015 09:40 AM
Todd C Wadas
2) Chassis problems..
Sep 23, 2015 11:31 PM
MikeyBoyesq
Sep 7, 2015 10:44 PM
Logan Collins
Sep 5, 2015 08:03 PM
