Z250 Jets
Old Feb 19, 2004 | 01:08 PM
BrocksZ's Avatar
Default Z250 Jets
Has anyone messed w/ the jets yet? How do you access the main jet?
Old Feb 19, 2004 | 03:50 PM
KFXBob's Avatar
Default Z250 Jets
I would like the same info, except how to access them, the Wife's Ozark needs to be richer, where do I start with sizes. Same Motor as LTZ I believe??
Old Feb 19, 2004 | 03:58 PM
BrocksZ's Avatar
Default Z250 Jets
As far as I know you can just go to the dealership and by single jets for like $4 or $5 each. I need to richen mine up too. Usually you skip the next two sizes up and go from there. Yeah I need to know how to take them out. Are they in the bottom of the carb or the top or what?
Old Feb 19, 2004 | 04:26 PM
hondabuster's Avatar
Default Z250 Jets
Heres a diagram of the carb, theres a plug (#41) thats covers the mixture screw, that may be all you need to adjust. If the motor is stock, the other jets should be fine. You need to remove the float bowl to get at the pilot and main jets, and remove the top, to get at the needle and clip.(#10 and # 12)
carb view
Old Feb 19, 2004 | 04:32 PM
BrocksZ's Avatar
Default Z250 Jets
Cool thanks. I thought the main jet was the long one on the top.
Old Feb 19, 2004 | 07:59 PM
BrocksZ's Avatar
Default Z250 Jets
This is the deal. I took the baffle/spark arrester off and I like the sound and it runs good, but I checked the plug and its white (running lean right?). So i wanted to rejet so that I could safely run without it and maybe make some air box mods if I have to. Don't really want to do air box mods but if I rejett I might have to. This is just until I get a pipe of course.
Old Feb 20, 2004 | 10:38 PM
BrocksZ's Avatar
Default Z250 Jets
Bump Think I could just move my needle up a clip?
Old Feb 21, 2004 | 12:26 AM
Default Z250 Jets
Heres 2 guides to jetting
carb tuning
carb tuning
Think I could just move my needle up a clip? Move the clip, down the needle, and that will richen up the midrange. If you modify the air box, or use a high flow air filter, you will need to rejet, or itll be too lean.
ReconBayou
Oct 31, 2022 05:37 PM
XxS0ccerstarxX
Sep 24, 2015 02:02 PM
XxS0ccerstarxX
Sep 22, 2015 02:40 PM
Nosniborpapa
Sep 12, 2015 05:54 PM
XxS0ccerstarxX
Sep 8, 2015 12:02 AM
