engine work on lt250
Old Feb 21, 2004 | 12:16 AM
motodog1's Avatar
Default engine work on lt250
was reading that this person was running a 92lt250 with an 1986rm 250 jug and cool head on it and he claims that it does somthing to the port timing that really makes it crank . has any one heard of any thinh like this??? can you run a power valve lower end with a older top end???
Old Feb 21, 2004 | 04:27 AM
LT250RSuperstar's Avatar
yeah Kiwi Craig did this mod or talks about it on his website.....
Old Feb 21, 2004 | 09:11 AM
sam250's Avatar
The powervalve on the 86 RM jug matches up with the LT's. Everything you need to know is on Kiwi Craig's Site.
Old Feb 22, 2004 | 02:57 PM
2Fast250's Avatar
well...is it worth doing the change from the LT to RM cylinder?? is it that much more power?
Old Feb 23, 2004 | 09:40 PM
2Fast250's Avatar
bump...
Old Feb 24, 2004 | 01:16 AM
motodog1's Avatar
im not sure yet about this mod i will have to do alot more researchon it. it sounds resonbale i guess but kiwis site is like old and is not very informative . it does have a bunch of specs that should be helpful though.. if i find out any thing ill post it for all to see...
Old Feb 24, 2004 | 02:12 AM
JustinJones's Avatar
The RM jug is a great bolt-on affair from what I have read. Although the 87 LT Jug has more potential as far as drag porting goes, if you can find a good RM cylinder for cheap, it's some of the best bang for the buck around for a trail/MX/play bike...
Old Feb 24, 2004 | 02:32 AM
motodog1's Avatar
so what have you heard about this mod?would a guy use a cylinder from an 86rm?thats whats getting me i guess does the 86 have a power valve? hell if this can be done cheaply i think ill get right on it.also do you think my pipe would work i just bought a new bills pipe. thanks for your input.. monty
Old Feb 24, 2004 | 09:29 AM
to my knowledge, only 86 and 87 RM jugs fit. the 88, 89, 90, 91 and 92 are all case reed engines.
Hankey Pankey
26
Oct 18, 2020 03:50 PM
EZRyde
EZ Ryde Exhaust
Jul 30, 2015 12:46 PM
toonces
Jun 30, 2015 11:19 AM
wildbill59
May 28, 2015 12:05 PM
