LT still foulin plugs...but only during warm-up...Please help.
Old Feb 26, 2004 | 09:41 PM
motodog1's Avatar
Default LT still foulin plugs...but only during warm-up...Please help.
150 should be plent o compresion. the tool is called a compression tester and all it is a guage with a hose and a fitting on the end. remove your plug.screw the fitting in to your head and give her a few swift kicks.the guage should read a set pressure and wala that would be your comp reading. also do it with open throttle and while machine is cold. there is a few differant ideas on how to check comp and this way has always worked for me...
Old Feb 29, 2004 | 09:23 PM
2Fast250's Avatar
asked my dad about checking the compression, and found out we ad a tool. With the carb off, first kick was 100, second was 150. Was very surprised at this. But called my dads friend, and he went through a few more things. We found that the spark plug end cap was actually not getting a good connection. Im really hopin all we need is a new cap to fix it. We kinda rigged it up to check the spark..and it looks a lot bigger. So i will update when i get the new cap to see if thats it.
Old Mar 1, 2004 | 08:55 PM
2Fast250's Avatar
ok well...we put a new spark plug cap on, and its still doing it. Actually its worse, it wouldnt even start today. The plug may be completely fouled now because we couldnt do anything to get it to spark. We sprayed it with carb cleaner, wiped it off, brushed it off, then finally blew it off with air compressor. This is usually more than enough to get it to spark, but not this time. Anything else to try???
Old Mar 1, 2004 | 09:51 PM
LT250Rodney's Avatar
If it still wont spark, I would turn to electronics. Coil and stator assembly, or a bad ground wire somewhere perhaps.
Old Mar 1, 2004 | 11:41 PM
  #15
2Fast250's Avatar
but see...if u use a screwdriver to test the spark instead of spark plug, it still fires...thats what gets me.
Old Mar 2, 2004 | 10:04 AM
  #16
sam250's Avatar
Get a shop manual. It shows you how to test your electrical system with an ohmmeter. Your coil might not be making enough juice until it gets hot.
Old Mar 2, 2004 | 01:15 PM
  #17
evhwg's Avatar
i changed the coil on mine and i still have symtoms like yours.
when i had the engine rebuilt the guy told me my stator looked fine. i am going to try a carb next seeing mine has a problem starting but when warmed up runs fine.
i cant see it being my CDI since my lights work and it runs great after it warms up.
Old Mar 2, 2004 | 06:54 PM
  #18
2Fast250's Avatar
at least someone has the same problem as me...does ur bog down when it fouls the plug? and can u clean ur's off to make it spark again? anyways...so ur gonna put on a whole new carb? i hope i dont have to do anything like that, but if i do, it will be a 38mm Air Stryker...maybe the carb is bad after all...haha
EIF
Apr 20, 2017 07:15 PM
scrounga
Honda Side by Sides
Mar 7, 2016 04:17 AM
Sassinm1
Sep 30, 2015 04:23 AM
Matt123
Sep 29, 2015 01:29 AM
2many2ride
Sep 27, 2015 04:35 AM
