Few ?'s about the LT250
Old Feb 27, 2004 | 10:27 PM
Danman2540's Avatar
Default Few ?'s about the LT250
I just baught an LT250 off a guy with no title and just wanted to know how I can tell what year it is and what the difference is between a quadrunner and a quadracer is and how i can tell which mine is. I would just like to know what ive got in case i need any parts. thanks for any info
Old Feb 28, 2004 | 01:04 AM
LT250Rodney's Avatar
Look at the cylinder on the right side (when your sitting on it). If it does not have a small round window in a rectangle shaped cover, then you have an 85-86 model. If it does then you have an 87-92. Also look at the suspension linkage. If it has a rod that activates the shock absorber, then its 87-90, if it has a motocross bike style linkage with a horseshoe sorta shaped link, then its 91-92. Those are both assuming youve got a powervalve.
Easiest was is get the VIN stamped off either the frame or engine. that will tell you for sure, assuming its original.
Old Feb 28, 2004 | 05:07 AM
rockrider's Avatar
Even easier, if your engine is grey its an 85-86, blue its an '87-'92. Rear suspensionwise, the above post is correct. And yes, they are way better than quadrunners.
Old Feb 28, 2004 | 08:04 AM
hondaguy1's Avatar
the serial number on the frame,, if it ends in a H its a 87, if it ends in an J its a 88. i dont know the rest of the years.
Old Feb 28, 2004 | 09:28 AM
killerKXF's Avatar
Hey...danman...where at in hazelwood....
Old Feb 28, 2004 | 05:42 PM
Imback's Avatar
The cc size should be readable on the cylinder, 85-86 are 249ccs and 87-92 are 246ccs if i remember correctly.
Old Feb 28, 2004 | 08:30 PM
Slacker1bob's Avatar
also, No reed cage is 85/86
"T" style seat on 87-92
Old Feb 29, 2004 | 03:15 PM
minnrider's Avatar
hey hondaguy.......how much for your 88 lt250r?
Old Feb 29, 2004 | 04:54 PM
Danman2540's Avatar
thanks fo the info guys, i guess i have the 85-86 cause i dont have a t seat, i have a silver engine with no window and its stamped 249cc. Now does anyone know how to distinguish between these two years. and 4 Killerkxf i live behind behlman. Also i see on my cylinder head it has TCHS engraved so does this mean that its been bored out, if so any idea how much. Lastly, what is the bolt pattern on th 85-86 and where can i get some deep dish(reverse offset) rims to widen the rear end. Are there any other ways to widen the rear?
Old Feb 29, 2004 | 05:37 PM
If it has TCHS on the side, it could mean that it has been ported. Usualy companies stamp their name on the cylinder. The only way to tell if it is bored is to pull the head and measure. The way to tell if it is a 85 vs a 86 is to see what size the carb it. The 85 has a 32mm carb and 86 is 34mm.
