three little bolts on side of Z250's motor...
Old Mar 8, 2004 | 05:56 PM
GTFZ250's Avatar
Default three little bolts on side of Z250's motor...
I accidently removed these nothing happed when I removed them just wanted to know what they were to and if they needed torqued before I ride it again just in case. They were on the right side of the motor if sitting on the quad and have a allen wrench depresion in the middle of them.
Thanks
Old Mar 8, 2004 | 06:38 PM
zquader's Avatar
that is where your clutch adjustmant is! it wont hurt anything ,just make sure there tight when you put them back
Old Mar 8, 2004 | 07:35 PM
Perwho's Avatar
Are you sure he's not talking about the oil filter....?
Old Mar 8, 2004 | 07:45 PM
zquader's Avatar
he said allen head !!! correct me if I'm wrong but the oil filter has reg hex head bolts to remove
Old Mar 9, 2004 | 07:21 PM
z250freak's Avatar
Actually I think that is for the oil filter. Last time i changed my oil filter i had to take off three bolts. Are they shaped in a traingle together?
o
o o Like this or something.
Old Mar 9, 2004 | 07:34 PM
zquader's Avatar
is it toward the front of the engine at the bottom or above the foot peg
Old Mar 9, 2004 | 07:43 PM
z250freak's Avatar
Its right above the footpeg.
Old Mar 9, 2004 | 07:58 PM
SuzukiZ250Kid's Avatar
I just checked my service manual and the hex shaped thing in the middle of the 3 nuts is the clutch adjuster cap. The 3 bolts are the Clutch Release Guide nuts. It doesn't have an torque numbers, just says to tighten them.
Old Mar 9, 2004 | 08:20 PM
zquader's Avatar
like I stated it it for the clutch
Old Mar 10, 2004 | 04:46 PM
hondabuster's Avatar
cover
The pattern of three, above the other pattern of three, is for the clutch. The lower pattern of three, is the oil filter cover.
