LT250r
Old Mar 10, 2004 | 09:44 AM
steelejones's Avatar
Default LT250r
Anyone ever hear if a Warrior shock will fit on a 90 LT ? My rear shock needs doesnt need to be charged it needs new seals etc and the dealer says he cant get any. I heard from somewhere that a Warrior shock would fit.
Anyone have any experience with this
Old Mar 10, 2004 | 11:51 AM
Slacker1bob's Avatar
Default LT250r
Heres a round about way of answering. I have heard that a raptor shock will fit on a 300ex. the 300ex shock is 14.5 inches long, and my LT250 shock is 14.5 inches long. If the Raptor and warrior(Both made by Yamaha) use the same rear shock, then I suppose it will work.
Old Mar 10, 2004 | 12:05 PM
Default LT250r
In a roundabout way are you telling me that you currently have a 300ex rear shock on your LT ?
Old Mar 10, 2004 | 12:06 PM
Default LT250r
are there any company out there that could rebuild my old LT shock i wonder...any idea what a rough cost might be ?
Old Mar 10, 2004 | 12:15 PM
jfisher304's Avatar
Default LT250r
Most suspension shops can do it. It isn't that hard to do so I would get a Suzuki shop manual and do it yourself. All you will have to do is get the nitrogen charged at the local dealer. The seals, bushing etc can still be obtained from Race-tech. (www.race-tech.com) If you insist on having someone else do it I HIGHLY recomend a company called MX-Tech. The can do everything form basic re-builds as well as custom valving jobs. The do excellent work, and have fast turn around and very fair pricing. The owner, Jeremy Wilkey, does a ton of the supercross works setups, and is one of KTM's head suspension guys. Their website is www.mx-tech.com
Hope that helps
Old Mar 10, 2004 | 12:24 PM
Default LT250r
I went to the race tech website, now im trying to figure out what type of shock (brand) comes stock on the 1990lt250r...
Old Mar 10, 2004 | 12:25 PM
jfisher304's Avatar
Default LT250r
Hang on and I'll look it up for you
Old Mar 10, 2004 | 12:29 PM
jfisher304's Avatar
Default LT250r
Shock Info & Products Data Price Qty Select
Shock Brand / Body Diameter KYB 40 mm
Shock Gold Valve Kit - Standard Type 1 SMGV 4001 $149.99
Shock Comments
Stock Shock Spring Rate 3.8 kg/mm
Ideal Rider Weight for the Stock Spring 125 lbs or 57 kg
Shock Spring Series
Custom Shock Spring Calculation and Available Rates SESP 891 $99.99
Shock Oil (less than one quart required) US1 $24.99
Shock Oil Seal (each)** SKOS 14 $9.99
Shock Dust Seal (each)** SKDS 14 $6.29
Shock Oil and Dust Seal Set (set)** SKOS 14S $15.99
Shock Shaft Bushing (each)** SMSB 1412 $9.99
Shock Seal Head Assembly (each)** SKSH 4014 $38.99
Bottom-Out Bumper (each) SKBO 01 $19.19
That should be all the info you need. Those prices are all race-tech direct. The shock is a KYB.
Old Mar 10, 2004 | 12:30 PM
Default LT250r
Oh i found it!
Old Mar 10, 2004 | 12:40 PM
Default LT250r
Man its gonna cost me a fortune to buy those parts and then send it away and have it installed etc.....
Would be much cheaper for me to buy a used Warrior or 300ex rear shock if it would fit.....Hey JFisher, have you heard of either of those fitting...the guy above says the 300ex shock is 14.5 and the kyb shock is 14.5....
Thanks for your help.....if all else fails im gonna bring my shock to the local dealer again so he can see exactly what i need and have him order from this place..
