open this LT250Rodney (reverse rev limiter)
Old Mar 18, 2004 | 09:51 PM
Koller's Avatar
Default anyone that knows anything about reverse rev limiter
i want to take the reverse rev limiter off when i get my z in a couple of days and was wondering if i got buried in mud and i had it more than half throtle to rock back and forth if it would harm the motor. could it possibly blow the motor. any responses would be greatly appreciated
Old Mar 18, 2004 | 10:04 PM
Vinson581's Avatar
no limiter in reverse, it is no auto!. reverse is like 1st gear all the time, and no rev limiter, would resulted in a melted piston.
Old Mar 18, 2004 | 11:36 PM
eiger2's Avatar
You can't just take the rev limiter "off". It is programmed into the CDI. Many aftermarket cdis dont have a limiter. If you have a wiring diagram, and can read it, you will see how to defeat it.
Old Mar 19, 2004 | 12:35 AM
LT250Rodney's Avatar
Just be careful if you disable it. A quad is not designed to go fast in reverse, and the handling is very jerky when moving quickly in reverse. It must be the caster. Anyways remember that when it is disabled, if your spinning like mad in mud and you bite into traction, the handling will be very unpredictable at higher speeds than the limiter allows.
Just dont want to see a fellow ATV'er get hurt is all.
Old Mar 19, 2004 | 02:47 PM
Koller's Avatar
but will i harm the motor spinning like hell in reverse or not
Old Mar 19, 2004 | 04:33 PM
sam250's Avatar
Default open this LT250Rodney (reverse rev limiter)
My friends raptor had a problem with the reverse rev limiter. It was kicking in while going forward. On that bike, all you have to do to disable it is ground it, which we did. It ran great but a few hours later, he put it in reverse, forgot about the disco'd rev limiter, hit the gas too hard, which made him go forward and push the gas some more and ended up on his lid. Pretty funny for everyone but him.
Old Mar 19, 2004 | 11:35 PM
I dont think there is any way in hell that disconnecting the limiter can melt your piston, the engine is still rotating in the same direction, your just reversing the output direction of the transmission. As long as you dont hold it at WOT for a VERY long time then you shouldn't hurt anything. So to answer your question, I would say no, it would be just like having the thing ***** out in first gear, since more often than not reverse and first are the same (or close) ratios.
Old Mar 20, 2004 | 02:24 PM
eiger2's Avatar
The reverse limiter is to protect YOU not the machine. It is a pain in the butt when yer in mud and want to get out backwards.
If you do go ahead and defeat it, put in a switch so you can select when to do it. I used a 3 way switch and wired it so that I could also turn it on when someone else is riding it forwards since I have an auto and if you hold er WOT she takes off a lil fast for novices.
Njrider1230
Jul 29, 2023 05:16 AM
JakeXBL
Sep 5, 2015 01:08 PM
mrmickman123
Technical and How-To Articles
Aug 30, 2015 10:37 PM
black_thunder
Aug 19, 2015 02:30 AM
