LT250R Steering Help please!!!!
Old Mar 23, 2004 | 03:24 PM
wheely's Avatar
Default LT250R Steering Help please!!!!
I have an 1987 Lt250r. I bent the steering stem and replaced it. Now my steering is way too tight. Any suggestions would be greatly appreciated and also get me back in the woods!!Text[img]i/expressions/face-icon-small-sad.gif[/img]
Old Mar 23, 2004 | 04:09 PM
sam250's Avatar
You probably did not put it together correctly. I did the same thing when I rebuilt mine. Verify the order of all the washers and other hardware with the drawing in your shop manual, if you don't have a manual you can see the parts diagram here.
Old Mar 23, 2004 | 04:48 PM
wheely's Avatar
Thanks for the info. I will check it out tonight. I hope this will fix the problem.
Old Mar 23, 2004 | 08:01 PM
LT250Rodney's Avatar
Also there is a bushing in the frame for the steering shaft. I'd suggest replacing it, since the bent stem likely over stressed it and made it wear. I dont think its expensive and itll tighten up the steering pretty well if its loose. By tighten I mean it will respnd quicker, not make it bind up.
Just a suggestion, is all.
Sep 30, 2015 01:37 AM
35dodge
Sep 29, 2015 09:40 AM
Levi Enstad
Sep 26, 2015 08:00 AM
Todd C Wadas
2) Chassis problems..
Sep 23, 2015 11:31 PM
Logan Collins
Sep 5, 2015 08:03 PM
