z400 oil change
Old Apr 15, 2004 | 12:24 PM
Koller's Avatar
Default z400 oil change
im about to change my oil for the first time on my bike and i was wondering if u guys change those 2 o rings by the oil filter every time u change ur oil. is it going to hurt the machine if u dont change those after changing the oil
Old Apr 16, 2004 | 12:41 AM
Mars's Avatar
You can get away with it once or twice.
If the "inside" one is worn or damaged the oil will by-pass the filter. If the cover o-ring is worn it just leaks.
I always keep one of each on hand............
PS. Change the oil warm. Drain the engine sump. Go easy on the bolts. (ALUMINIUM)
Old Apr 16, 2004 | 12:07 PM
Koller's Avatar
yeah it should be ok it will be the first oil change.
Old Apr 16, 2004 | 12:12 PM
yamahawarriormods's Avatar
yeh it will be okay the first couple times as long as there not damaged at all
Old Apr 16, 2004 | 10:12 PM
Koller's Avatar
i figured it would be ok i just wanted to make sure
ultangler
Nov 30, 2024 01:35 AM
ReconBayou
Oct 31, 2022 05:37 PM
Jackg17
Ask the Editor
Jul 16, 2018 04:01 AM
Jackg17
Sep 26, 2015 09:30 PM
Sw00p
Sep 24, 2015 02:50 PM
