lt 230 question
Old Apr 27, 2004 | 09:35 PM
mudrover's Avatar
Default lt 230 question
My friend has a stock 300ex i was thinkin of drag racin him just for fun but i dont want to be embarassed i am getting a DG pipe and he out weighs me by 30 pounds think i have a chance and what could i do for realativly little money to make my lt 230 faster thanks sorry about the long post
Old Apr 27, 2004 | 10:47 PM
vexing2's Avatar
get a freeflowing air filter...KN or Uni... I drilled some holes in the airbox... readjust the carb after changes.. you shouldn`t be embarassed... are you a manual clutch??
Old Apr 29, 2004 | 08:11 PM
mudrover's Avatar
I already have taken my air box lid off and have a uni air filter installed i am just waiting to get my pipe what carb adjustments should i make? and yes it is a manual clutch.
Old Apr 29, 2004 | 11:54 PM
lt230racer's Avatar
You will probably need a bigger main jet. With the pipe you will be able to take that dirty 300ex for sure, unless you cant ride.[img]i/expressions/face-icon-small-happy.gif[/img]
Old Apr 30, 2004 | 09:40 PM
mudrover's Avatar
What size main should i go to also should i change my tire size i have 22x11x9 s on the rear thanks
Old Apr 30, 2004 | 11:37 PM
lt230racer's Avatar
the main jet size depends on the mods you have, i have a 130 and i know that would be way too rich for you, i would try a 120 and go up from there. As for the tires, if they are ballon tires,it would handle better with a set of lower profile tires, with 22's you would have a bit more ground clearance, but its up to you. The first thing you would do for more top end is regear. That is the first and cheapest thing I did.
Old May 1, 2004 | 09:12 AM
vexing2's Avatar
I think reworking the suspension would be the first step in trying to go much faster..I have puyt a set of front shocks off a 300ex on my quad but, I still have to raise the top shock mount an inch or so... the front end really picked up in height making the front end to light.. I know my front shocks were trash .. so far I have a hundred bucks in project... much cheaper than new shocks and lots better than old ones
EIF
Apr 20, 2017 07:15 PM
shimanok2
Jan 29, 2016 07:37 PM
Ahtatu
Sep 28, 2015 12:14 PM
2many2ride
Sep 27, 2015 04:35 AM
Quadzilla Heritage
Sep 25, 2015 01:39 PM
