paddles for a lt250r
hi im looking for paddles for a lt250r but im not sure what ones to get i was thinking about buying some used ones because im kinda new at this and i dont want to spend to much on paddles that im prolly gonna use for only once a year because i live pretty for away from the dunes and i was also thinking not to get the rim on the tires because i noticed a lot of people like to get rims for their paddles im not sure what to get??? so i need help
thanks
thanks
Welcome to the forums.
you have many many choices to make regarding paddles... depending on your intended use.
I buy seperate wheels because I change b/w paddles and knobbies often... and if you've ever changed your own tires... they can be a real B*#@%... not to mention that your wheels can get really banged up from the process of changing the rubber frequently.
Wheels are typically the 'cheap' portion of the package anyhow... You should be able to find some really decent used paddles... try looking on fleabay.
You'll need to research what type paddle best suits your needs also..
Good luck!
Good luck!
When I got my quad the previous owner had bought haulers but took them off after one ride. He preferred the sand skate 2s. I'm guessing he liked donuts...(not the edible kind though) and roosting at the top of a dune as compared to the massive straight line traction of a hauler.
Quadzilla Heritage
Sep 25, 2015 01:39 PM
Aug 25, 2015 11:16 PM
