finally blew it!!
Old Jun 14, 2004 | 12:10 PM
1987LT250's Avatar
Default finally blew it!!
ok i dropped a thrust washer now ive seen people talking bout these but do i need them and what makes them break and do so much damage? if i werent to use them do they make a customized piston so the slack between rod and piston isnt there?
ok not a thrust washer one of the washers that sit on each side the top of connector rod sorry was just informed
Old Jun 14, 2004 | 03:48 PM
Michwolv60's Avatar
how is the 38mm carb with those mods? Sorry i am off subject, but someone told me that my38mm is too big for my mods, so i was just wondering how yours was, and if I should just get a different carb, i just bought mine,
Old Jun 14, 2004 | 05:08 PM
sam250's Avatar
From the "Suzuki Sc**w Ups" section of the legendary LT500 RX by Dr. Q...
SU#7) Those wonderful wrist pin washers. These are a real sore point w/me. These are made of case hardened steel and are prone to fracture when left in the motor for any length of time or exposed to detonation.They are a necessary evil however. Many come out of the box w/microscopic cracks that eventually lead to failure and ruining your nice cylinder/head.
Rx#7) No real good answer. We used to have hardened alloy washers made and use an RM250 wrist pin bearing. I have also sent them out for x-raying before using. (about 15% of the batches we sent were NO GOOD!) I may make the alloy ones again. Even if they break (none ever did) they won't tear up the motor too bad.
Old Jun 14, 2004 | 05:26 PM
1987LT250's Avatar
my carb works great...when its not blown up. and ty sam
Old Jun 14, 2004 | 05:38 PM
sam250's Avatar
np
Old Jun 14, 2004 | 06:58 PM
Michwolv60's Avatar
what do u mean by no toil filter?
Old Jun 14, 2004 | 07:24 PM
1987LT250's Avatar
just a foam air filter brand being no toil
ReconBayou
Oct 31, 2022 05:37 PM
Bernhard
Sep 25, 2015 12:45 PM
Nosniborpapa
Sep 12, 2015 05:54 PM
byronman
Sep 6, 2015 06:34 PM
