zilla main bearings
Old Jun 19, 2004 | 04:54 AM
420EX's Avatar
Default zilla main bearings
I have heard about some problems with the zilla main bearing holders, what exactly goes wrong with them and how do you fix it?
Old Jun 19, 2004 | 02:53 PM
rooster123's Avatar
The problem is a bearing boss issue. What happens is the bearing holders on the cases overheat and the boss,s become oblonged. Allowing movement in the bearing race It will always cause engine failure if the problem happens to you. If the zilla has not been modded or raced hard it's not a big problem but if your engine has had port work and mods. Over time your probably going to have a problem. There is a company called tudors performance. That will boss your cases with a steel liner some use brass but they say the steel boss's are better and you will not have anymore problem's But you must split your cases or send them the engine...
Old Jun 21, 2004 | 11:15 AM
Duneaddict's Avatar
Do a search on here regarding Tudors before you send them ANYTHING!
A little more detail to what rooster was saying.... The bearings and cases are dissimilar metals, and expand at different rates with temperature. Over time and use, the bearing seat (boss) gets 'hammered' out and oblonged so as the bearing is no longer retained properly. This usually causes increased vibration, and eventual failure of crank seals.
My $.02
Old Jun 24, 2004 | 05:35 PM
kruzoffman's Avatar
just a quick quistion how much is it to fix...
Old Jun 25, 2004 | 12:06 AM
UKzilla's Avatar
also worth a note is that suzuki did do there own fix in later models and the steel inserts may already be fitted, they were casted in by the looks of my cases and on one side it wasnt atall obvious
2quiker
Mar 22, 2022 08:36 PM
Alex G.
Sep 19, 2015 06:34 PM
Ridgebackguy86
Sep 19, 2015 12:48 PM
Nosniborpapa
Sep 12, 2015 05:54 PM
Elkaholic
Sep 6, 2015 02:44 PM
