Lowering the Z400
Old Jun 29, 2004 | 11:34 PM
Ball's Avatar
Default Lowering the Z400
What is the best way to lower the Z in the rear? I race XC so I cant really give up ground clearance. I have heard of fabricating new shock linkage but it puts the shock down too far and kills all hopes of ground clearance. Any suggestions?
Old Jun 30, 2004 | 05:01 AM
craZ400's Avatar
Gain weight...or drop some serious cash on a new swing arm that use a more clearance friendly shock set up?
Old Jul 1, 2004 | 11:02 PM
mucky's Avatar
ELKA SUSPENSION makes a link that drops the rear down about a inch but it does cost almost 2 bills
Old Jul 2, 2004 | 02:24 AM
craZ400's Avatar
Hey mucky, that's what he DOESN'T want. He wants to drop the suspension w/o losing clearance under the linkage.
Old Jul 2, 2004 | 10:28 PM
mucky's Avatar
You can still use the link and yes it does lower the bike a little but it
also gives you longer swingarm travel
but you can adjust your preload springs .
thats what I had to do to gain clearance and still keep the suspension level
and changing the swingarm might not help because most aftermarket arms are built
to the same specs as stock but are lighter and stronger and sometimes longer
or you get bigger tires and regear the bike to handle it and then use the link bar
to compensate for the height
exmotocrosser
Sep 13, 2019 06:12 AM
NewGuy2481
Oct 6, 2015 05:54 AM
Quadzilla Heritage
Sep 25, 2015 01:39 PM
XxS0ccerstarxX
Sep 22, 2015 08:07 AM
1ArmBandit
Sep 8, 2015 08:59 PM
