z400 problems any answers
Old Jul 4, 2004 | 07:08 PM
z400ridehard's Avatar
Default z400 problems any answers
I have a 03 z400 i have change the sprockets and chain rear axle bearings and i still keep have problems with the chain falling off alot is there any kind of giudes i can buy that will fix this problem
Old Jul 4, 2004 | 09:15 PM
z838mx's Avatar
keep it tight it wont fall off. If its properly adjusted you wont have issues. I have had mine fall off but only when im to lazy to maintain it.
Old Jul 4, 2004 | 09:31 PM
i do adjust it and oil as often as i can see it needs it
Old Jul 4, 2004 | 09:49 PM
CHEWBACCA's Avatar
if the chains too loose, don't change the sprockets unless the teeth are worn down. Try taking a link out of the chain.
Old Jul 4, 2004 | 09:52 PM
z838mx's Avatar
Dont take a link out of the chain replace it if it has streched to much if you think cutting a link out is the awnser the only awnser you will get is a broke case when the chain breaks because it streched to much. Cutting a link out is a bad idea unless the chain is fairly new.
Old Jul 5, 2004 | 08:40 PM
the chain and both sprockets are both new have like ten hours on them
is it possable for a sprocket to be out of round it seems like when i push it by hand that the chain gets light then loose
axle is straight
Old Jul 5, 2004 | 09:12 PM
z838mx's Avatar
if it tight and loose then you chain is junk and needs to be replaced. I have had that happen and it sucks. If you do alot of hard takeoffs or alot of wheelies that can happen, not saying it is what made it do that. is it an o-ring chain. Your next chain try an x-metal chain mine has held up very well so far and my motor has a ton of mods. Just a sugestion might not be the right awnser for you.
Old Jul 5, 2004 | 09:35 PM
FsT4WrD's Avatar
Is the skid plate bent and causing it to throw the chain ?
Old Jul 5, 2004 | 11:35 PM
the chain is an mx3 non o-ring i ride wheelies any time i have enouph room to ......i had swing arm aluminum skid plate and i took it off cause i couldn't ajust it all the way with it on so i took it off and i am running with no skid for right now....
Old Jul 6, 2004 | 12:46 AM
craZ400's Avatar
I'd pull the rear sprocket off and see if it's bent, just lay it on something flat and see if it wobbles. If the chain is tight then loose, I'd bet it's the sprocket.
