what makes coolant flow out of hole on a lt?
Old Jul 12, 2004 | 09:21 PM
800screws's Avatar
Default what makes coolant flow out of hole on a lt?
the little factory hole that is next to the coolant drain bolt, what makes coolant drip out of there. i am replacing the entire waterpump, but i'm curious to way it started dripping?
Old Jul 12, 2004 | 09:57 PM
mahnster's Avatar
I think its a bad seal but im not 100% positive.
Old Jul 12, 2004 | 10:08 PM
donzilla's Avatar
it was most likely the mechanical seal . it is usally the firstto let coolant threw then goes out from there [<u>DONT FORGET THE BOLT THAT HOLDS THE IMPELLER ON IS LEFT HANDED THREADS !!!!!</u> make sure you also put a new bolt seal washer on it .
Old Jul 13, 2004 | 12:08 AM
LT250Rodney's Avatar
Its called a weep hole. It is there to let you know when the seal goes bad. Your seal has gone bad. Id suggest replacement.
Old Jul 13, 2004 | 07:36 AM
800screws's Avatar
thanks, the mech seal was cracked, just wanted to know exactly why it drips. thanks everybody!!
Old Jul 13, 2004 | 08:16 AM
blackballed's Avatar
If the seal was cracked and not worn; this is sometimes an indication of interrupted flow to the pump (producing heat).....and then thermal shock to the seal itself when coolant is re-introduced.
Old Jul 13, 2004 | 06:17 PM
800screws's Avatar
ah, don't say that.
Old Jul 14, 2004 | 09:54 AM
fivel250rman's Avatar
I am trying to get this mechanical seal for my uncles 87 however the suzuki dealer says this part is discontinued any suggestions?
Old Jul 14, 2004 | 11:53 AM
Grainger and a few other places are now selling mechanical seals (most are minimum 5/8" shaft, unfortunately); yet not sure what type you've got.
You'll need a shaft diameter and seat O.D. (along with a seat cross-section diameter if this is a typical type 21 mechanical seal) to check around.
Old Jul 14, 2004 | 02:54 PM
emmerth's Avatar
You can get the whole repair kit on ebay for $26. He has 85-86 and 87-92 kits.
Here is the link ebay auction
