Kick Start Question
Old Jul 26, 2004 | 11:38 PM
cabral91's Avatar
Default Kick Start Question
Hi I bought a 1987 LT230 Quad sport and was wondering what could I do to have the bike start in just a few kicks instead of 20. I have already changed the spark plugs. Is there anything else I can do that is not to expensive. I am kind of new to working on bikes so try to please explain. Thanks for all your help.
Old Jul 26, 2004 | 11:42 PM
bamalt230's Avatar
im not sure if my case is the same as yours.but when i first got my 230,it did the same thing.but after running it for about a week and tweeking everything it starts on the first kick every time.have you tried choking it or using the decompression perch ?you might also try adjusting the carb.just my 2 cents
Old Jul 26, 2004 | 11:47 PM
mudrover's Avatar
I have one and they are just hard to start. Try priming the cylinder by useing the decompression lever and kicking it extremly slow a few times then kick as hard as you can. also you could pull it behind a truck or other quad in gear an pop the clutch to start it
Old Jul 27, 2004 | 12:26 AM
cabral91's Avatar
I forgot to mention that once the bike is started and warmed up I can shut it off and I can restart it with the first kick. Which is probably normal anyway.
Old Jul 27, 2004 | 12:44 AM
cabral91's Avatar
I know this is a stupid question but, [img]i/expressions/face-icon-small-blush.gif[/img]
Where is the decompression lever?
Old Jul 27, 2004 | 11:54 AM
bamalt230's Avatar
it is the little lever right above the clutch.but the actual peice is on the right side of the engine.be sure to watch it because alot of times when i pull mine it gets stuck,but u can just reach down there and push it back up.hope this helps
alix
Jun 28, 2015 03:28 AM
02Chevrolet
1) Engine problems..
Jun 23, 2015 12:12 AM
Dabears1983
Jun 16, 2015 12:17 PM
4trax300ex
Jul 29, 2000 11:41 AM
rking85
May 20, 2000 11:01 PM
