king is sick
Old Jul 28, 2004 | 10:08 PM
dcb's Avatar
dcb
Default king is sick
my king quad isn't running good it's a 1998 lt-f4wd with a300cc .
It bogs out after it has run for a minute, like the plug is fouled.
I repaced the plug added some dry gas and carb cleaner but it still has not helped.
would any one have any ideal or would have had a simular problem?
any help greatly appriciated, thanks Dave
Old Jul 28, 2004 | 10:22 PM
superlowgear's Avatar
i have a 1992 king and it had the same problem we took the carb off and checked the needle make sure the float is sealing the needle completely if it is try tightning the jet of the out side of the carb
it is on the bottem and toward the front when you tighten this it will up your idle so just unscrew the idle nnob until it sounds right may take two or three time but that was my problem
any questions just lemme know
hope i helped
Old Jul 29, 2004 | 01:46 AM
Glenlivet's Avatar
Fuel supply problem. Check the tank vent (take off the cap and blow thru the hose on top), the petcock and its screens (see if putting it on reserve makes it run properly), the fuel lines, the fuel pump, the carb body for plugged passages, needle and seat.
Old Jul 29, 2004 | 01:05 PM
dcb's Avatar
dcb
thanks i will pull the carb and check it out. also the valve and lines look good.
What will be the easiest way to take the carb of. does the air box have to be removed ?
thanks dave
Old Jul 29, 2004 | 01:59 PM
Glenlivet's Avatar
just loosen the clamps and work it up and out. Don't forget the fuel pump for potential trouble. diaphragm pump mounted between the front frame uprights.
shimanok2
Jan 29, 2016 07:37 PM
Ahtatu
Sep 28, 2015 12:14 PM
jsmit116
Sep 18, 2015 10:34 PM
David Diaz
Sep 8, 2015 04:44 PM
DGNAZ
Sep 5, 2015 09:14 PM
