lt wont turn//////
Old Aug 11, 2004 | 04:32 PM
RoscoePW's Avatar
Default lt wont turn//////
i have an lt 230 and theres no wieght on the front, its a wheelie machine and whn the handle bars turn, theres no wieght so the tires run sideways, i cant think of anything other that tying wieghts to it....
Old Aug 11, 2004 | 08:32 PM
BIGGONE's Avatar
Try unloading some air psi. What are you runing for psi?
It also sounds to me like you may have the wrong wheel size { too small} something don't sound right. I'm just guessing for myself right now.
Try runin 2lbs psi on the fronts & 3 - 4 lbs psi in the rear see if that helps.
Need more info.
Old Aug 12, 2004 | 11:12 AM
RoscoePW's Avatar
thanks ill try it, but does that increase risk of tires poppin?
Old Aug 12, 2004 | 02:48 PM
BIGGONE's Avatar
It shouldn't risk anything, I'm guessing as to what you may have for a remedy for this.
It's hard to know without having a good clear picture of what the whole out look is.
