LT 80 extremely need help
Old Aug 21, 2004 | 11:20 PM
poopypants's Avatar
Default LT 80 extremely need help
OK....i have an 87 LT 80....heres the story....i bought it off this dude for 50 bucks....he says his cousin rode it and then tried to put water in the gastank to make more gas...what a dumbass....so anyway, i've cleaned the carb....rebuilt it....has pretty decent compression...the only thing is that it will start but only run with the choke on....even after it gets warmed up...if you give it more than 1/3rd throttle....it bogs....please help me!!!!!!!!!!!!!!!!!!!!
Old Aug 22, 2004 | 11:28 AM
bsb64's Avatar
Take the carb off. Take the carb apart and clean it completely.......
Old Aug 22, 2004 | 11:42 AM
95wolv's Avatar
If you make sure the carb is spotless (blow out all ports and tiny passages) and it still bogs, try jacking up the back end and run it with the tires off the ground.If it revs better, you may have gummed up clutch weights or the sheaves on the front or rear aren't opening and letting the engine rev, so it bogs and makes no power. I bought my son an 87 LT80, it ran fine, but had no power unless you let it run a long way, it would gradually get faster, but never go fast, and the bottom end was so bad, it would barely go up any incline without squealing the belt and barely moving. I took the belt cover off to check the clutches, the front weights were jammed, and the shaft it moved on rusty, cleaned that up, then went to the back pulley, it was locked at about 1/4 open, took it completely apart, it was jammed full of dirt and dry grease so the sheaves couldn't move. after cleaning it up, and replacing the weights ( actually, I milled new nylon sleeves for the metal rollers) it ran like a champ, spin the tires from a stop, and had great top end and revved real good. One more thing to check, take the drain plug from the bottom of the muffler, and see if a lot of oil/ moisture drains out. No 2 stroke will run for beans with a plugged up exhaust, some have even had to heat the muffler up with a torch to burn all the crud out to make them run right.
Old Aug 22, 2004 | 08:40 PM
quadduck's Avatar
Try going to the kids mini quad forum, there is a guy on there who goes buy th e name of lt80. He knoes every trick in the book and even some that he didn't put in the book.
Old Aug 22, 2004 | 10:50 PM
hondabuster's Avatar
Hey, P...P, you may want to reply to this thread.
nicknames
Old Oct 12, 2005 | 06:25 PM
fireman516's Avatar
have you found your problem yet? i have a lt80 that will run great while it is choked, or when you restrict the intake opening by placing a finger over the intake opening i could use any kind of help. thanks
MikeyBoyesq
Sep 22, 2015 10:02 AM
01ssls1
Sep 22, 2015 06:50 AM
Polaris Side by Sides
Sep 15, 2015 03:33 AM
MikeyBoyesq
Sep 7, 2015 10:44 PM
Elkaholic
Sep 6, 2015 02:44 PM
